Ether Channeling
I have a server that has two GB nics and have "teamed" them using HP teaming software. I would like to configure the switch to make thia a 2GB connection. How would I do this?
Mike
1 REPLY
Re: Ether Channeling
What you should be checking with the HP Software is that if HP supports LACP or 802.1ad protocol for the Etherchanneling to the Cisco Switch.
If they do support the above mentioned protocol then you may take a bit of guidance from the below link otherwise, I would have had preferred to talk to the HP Support.
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_configuration_example09186a008014edfa.shtml
Hope that helps,
Please rate if it helps,
Kind Regards,
Wilson Samuel
294
