Etherchannel & 3012 Blade Switch
I have a problem configuring an etherchannel on a 3012 blade switch.
I'm installing a new IBM blade enclosure with 2 3012 switches. Both switches are configured to bundle the 4 external 1Gb ports into a single etherchannel. Switch 1 is configured and working properly. Switch2 is loaded with an identical configuration, but the switch will not all me to do a no-shut on the external interfaces. when I try to do this, it comes back with 'shutdown is not allowed on these ports'.
Does anyone know if there is some extra configuration required for type of switch?
Frank
I've pasted the config below:
no service pad
service timestamps debug uptime
service timestamps log datetime localtime
service password-encryption
hostname switch1
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone AEST 10
clock summer-time AEDT recurring 1 Sun Oct 2:00 1 Sun Apr 3:00
system mtu routing 1500
authentication mac-move permit
no ip domain-lookup
ip name-server 10.64.16.127
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Port-channel1
description Link to 6509
switchport mode trunk
interface FastEthernet0
ip address 192.168.70.127 255.255.255.0
interface GigabitEthernet0/1
switchport access vlan 200
switchport mode access
spanning-tree portfast
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
channel-group 1 mode on
shutdown
interface GigabitEthernet0/16
shutdown
interface GigabitEthernet0/17
shutdown
interface GigabitEthernet0/18
shutdown
interface Vlan1
ip address 10.70.0.33 255.255.0.0
ip default-gateway 10.70.0.15
ip classless
no ip http server
ip http secure-server
ip sla enable reaction-alerts
logging source-interface Vlan1
logging 10.11.2.25
banner motd ^CCCCCCCCCC
                   WARNING
It is a criminal offence for unauthorised persons
    or devices to connect to this system.
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^C
line con 0
login local
stopbits 1
line vty 0 4
exec-timeout 30 0
login local
transport input ssh
line vty 5 15
login
transport input ssh
ntp server 10.1.17.22
mac address-table static 1c17.d3f1.511d vlan 1002 interface GigabitEthernet0/19
end
642
