Etherchannel across two Cisco 3750 in a stack?
Can I setup a server with to load balance across the two switches that are in a stack? I've heard that you would need - multichassie etherchannel and this is only supported on the 6500 series? Thank you.
1 ACCEPTED SOLUTION
Silver
Re: Etherchannel across two Cisco 3750 in a stack?
You'er welcome and please if you find my post helpfull please rate.
Silver
You can do that but you need to make sure that the IOS supports it. Etherchanneling is supported across multiple 3750 Switches in the same stack.
Hope this helps,
Appreciate your rating,
Do you happen to know what IOS I would need? Thank you.
Silver
The feature you are looking for is cross-stack Etherchannel. You will need IOS of 12.2(25)SEC or higher. Below is the link:
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00806cb982.shtml
Let me know if you need anything else,
Thank you, appreciate it!
Silver
259
