01-28-2012 02:45 AM - edited 03-07-2019 04:36 AM
hi,
I m trying etherchannel b/w two 3560 L3 switch in Cisco packet tracer. i am able to ping both switch vic v. bu when i am shut down one of port in port channel not able to ping between switch. i want to connect my two location with 2 3550 with redudancy. o/p are below. can any suggest what will be the issue.
hostname SW1
interface FastEthernet0/1
switchport access vlan 100
interface FastEthernet0/23
no switchport
channel-group 1 mode on
no ip address
duplex full
speed auto
interface FastEthernet0/24
no switchport
no ip address
duplex full
speed auto
interface Port-channel 1
no switchport
ip address 10.10.10.1 255.255.255.252
interface Vlan1
no ip address
shutdown
interface Vlan100
ip address 192.9.100.100 255.255.255.0
ip classless
ip route 192.9.193.0 255.255.255.0 10.10.10.2
end
SW1#
SW1#
SW1#show etherchannel port-channel
Channel-group listing:
Group: 1
Port-channels in the group:
Port-channel: Po1
Age of the Port-channel = 00d:00h:36m:35s
Logical slot/port = 2/1 Number of ports = 2
GC = 0x00000000 HotStandBy port = null
Port state = Port-channel
Protocol = PAGP
Port Security = Disabled
Ports in the Port-channel:
Index Load Port EC state No of bits
0 00 Fa0/24 On 0
0 00 Fa0/23 On 0
Time since last port bundled: 00d:00h:07m:07s Fa0/23
SW1#
SW1#show etherchannel summary
Flags: D - down P - in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 1
Number of aggregators: 1
Group Port-channel Protocol Ports
1 Po1(SU) PAgP Fa0/23(P) Fa0/24(P)
hostname SW2
switchport access vlan 193
no switchport
no ip address
duplex full
speed auto
no switchport
no ip address
duplex full
speed auto
no switchport
ip address 10.10.10.2 255.255.255.252
interface Vlan1
no ip address
shutdown
interface Vlan193
ip address 192.9.193.100 255.255.255.0
ip classless
ip route 192.9.100.0 255.255.255.0 10.10.10.1
end
SW2#
SW2#show etherchannel port-channel
Group: 1
Port-channel: Po1
Age of the Port-channel = 00d:00h:33m:10s
Protocol = PAGP
0 00 Fa0/24 On 0
0 00 Fa0/23 On 0
Time since last port bundled: 00d:00h:08m:21s Fa0/23
SW2#
SW2#show etherchannel summary
d - default port
SW2#
Solved! Go to Solution.
01-28-2012 04:11 AM
I tested it and got the same result as you so I think you should stay away from PT to test etherchannels and stick to GNS3 if you can do with mode on or use real devices if you want to use PagP or LACP.
Regards.
Alain
01-28-2012 03:17 AM
the outputs from sh ether summary do not corresponf to your config as you configured a L3 portchannel with no negotiation protocol and it appears as a L2 portchannel with PagP.
So I'm gonna try it on PT and tell you if I got the same result.
Regards.
Alain
01-28-2012 04:11 AM
Regards.
Alain
01-29-2012 07:57 PM
i tried in my office with 2 3550 with back2back connection and its working fine. its showing RU(L3 channel).
thanks Alain.
Madhukant
