11-02-2014 11:09 PM - edited 03-07-2019 09:20 PM
Hello All,
I configured etherchannel between two 2960 switches.
Both the switches have SVI with subnet 192.168.2.3 and 192.168.2.4
I have another vlan3 on one of the switch.
so when i created etherchannel between two Gig ports and allowed both the vlans,it gave me an error messg,
Nov 3 12:41:07.332 KSA: %EC-5-CANNOT_BUNDLE2: Gi1/0/19 is not compatible with Gi1/0/20 and will be suspended (vlan mask is different)
Nov 3 12:41:07.339 KSA: %EC-5-CANNOT_BUNDLE2: Gi1/0/19 is not compatible with Po1 and will be suspended (vlan mask is different)
Nov 3 12:41:07.339 KSA: %EC-5-CANNOT_BUNDLE2: Gi1/0/20 is not compatible with Po1 and will be suspended (vlan m
May i know why....
11-03-2014 01:57 AM
This usually happens when there is a configuration mismatch on the 2 ports you are assigning to the etherchannel.
Try removing all commands from the interfaces except the etherchannel commands and put the allowed vlan command on the port channel instead
11-03-2014 03:42 AM
Hello Mudasir
This will be a problem of allowed vlan mismatch. All the interfaces which are going to add in the etherchannel must have same allowed vlan on both sides.
You can check for the allowed vlan on all the interfaces as well as on Port-channel.
You can see the below forum having the same problem:
https://supportforums.cisco.com/discussion/9757346/etherchannel-prob
Mukesh Kumar
Network Engineer
Spooster IT Services
11-03-2014 12:39 PM
Hello
Can you post the config of the physical interfaces in the PC and of the PC itself.
res
Paul
