Community Member
etherchannel between catalyst 4908G and 3750G
hi all,
just want to post a situation here. i have 2 catalyst 4908G (8-port) with
bridging enabled. it was configured to run as redundant switch router for vlan
with port #8 configured as etherchannel connected to port #8 of the second switch
with port-channel subinterface and encapsulation configured as well.
everything works fine until the second switch fails.
we replaced the second switch with catalyst 3750G (12 port). the bridging was
configured and port #12 was assigned to connect to port #8 of the catalyst 4908G
but unfortunately i cannot ping the ip address of the bridge of the catalyst 3750 from
our network neither i can ping the ip address of the bridge of catalyst 4908G from the console
of the 3750 switch. what seems to be the problem?
all interfaces were verified as up and running.
the following are the configuration of the bridge and etherchannel of the 2 switches:
catalyst 4908G:
interface port-channel1
no ip address
no ip directed-broadcast
hold-queue 300 in
interface port-channel1.1
encapsulation isl 1
no ip redirects
bridge-group 1
---output cut
interface GigabitEthernet8
no ip address
no ip directed broadcast
channel-group 1
interface Bvi1
ip address 172.25.x.x netmask
ip helper-address 172.25.a.b
no ip redirects
standby 1 priority 105 preempt
standby 1 ip 172.25.1.1
---output cut
catalyst 3750
hold-queue 300 in
---output cut
interface GigabitEthernet12
channel-group 1 on
interface Bvi1
ip address 172.25.x.y netmask
no ip route-cache cef
standby 1 preempt
---output cut
Hall of Fame Super Bronze
Re: etherchannel between catalyst 4908G and 3750G
Any reason why are you bridging ? The switch bridges by default, no need to use BVI.
This configuration would be useful when you have a router and you want this router to behave like a switch.
I also don't see the need for etherchanneling on a single link. Etherchanneling is used when you want to bundle 2 or more links for bandwidth aggregation and/or faul tolerance.
Your configuration should be as follow:
catalyst 4908G:
switchport mode trunk
interface vlan 1
no ip redirects
catalyst 3750
interface vlan 1
standby 1 preempt
Community Member
thank you for your quick response mr. EdisonOrtiz. i do have a router. basically the function of those 2 switches is to work redundantly if either of them fails one of them will be up and running. i've tried to shut down the first switch (4908G) to see if the second switch (3750) will provide the network connectivity but it fails. i cannot ping any ip address in the network. do you think the trunking from 4908G to 3750G will resolve the problem in the 3750G switch?
Community Member
thank you for your quick response mr. EdisonOrtiz. i do have a router. the reason i used bridge is to group all subinterfaces that i configured for vlan trunk. basically the function of those 2 switches is to work redundantly(STP)if either of them fails one of them will be up and running. i've tried to shut down the first switch (4908G) to see if the second switch (3750) will provide the network connectivity but it fails. i cannot ping any ip address in the network. do you think the trunking from 4908G to 3750G will resolve the problem in the 3750G switch?
I meant, the BVI configuration will be on a router, not that you need BVI if you have a router in the topology.
Please follow my suggestions to make this work.
Community Member
Sir EdisonOrtiz,
How are you Sir? I tried the configuration that you gave me but the problem is that 4908G switch was not recognized switchport command thus I cannot make the interface as trunk. So still i cannot connect to my 3750 switch. By the way the reason for BVI configuration was for routing. and for you to have a better feel of our switch configuration below is the configuration for both 4908G and 3750 switch. note: 4908G switch is the active.
4908G-L3 config:
bridge irb
interface Port-channel1
no ip address
hold-queue 300 in
interface Port-channel1.1
encapsulation isl 1
no ip redirects
bridge-group 1
no ip address
interface GigabitEthernet1.1
encapsulation isl 1
no ip redirects
bridge-group 1
interface GigabitEthernet1.10
encapsulation isl 10
ip address 172.25.x.y 255.255.b.z
ip helper-address 172.25.a.a
no ip redirects
standby 10 priority 105 preempt
standby 1 ip 172.25.f.g
interface GigabitEthernet2
no ip address
interface GigabitEthernet2.1
encapsulation isl 1
no ip redirects
bridge-group 1
interface GigabitEthernet2.20
encapsulation isl 20
no ip redirects
standby 20 priority 105 preempt
interface GigabitEthernet3
no ip address
interface GigabitEthernet3.1
encapsulation isl 1
no ip redirects
bridge-group 1
interface GigabitEthernet3.30
encapsulation isl 30
no ip redirects
standby 30 priority 105 preempt
interface GigabitEthernet4
no ip address
interface GigabitEthernet4.1
encapsulation isl 1
no ip redirects
bridge-group 1
interface GigabitEthernet4.40
encapsulation isl 40
no ip redirects
standby 40 priority 105 preempt
interface GigabitEthernet5
no ip address
interface GigabitEthernet5.1
encapsulation isl 1
no ip redirects
bridge-group 1
interface GigabitEthernet5.50
encapsulation isl 50
no ip redirects
standby 50 preempt
interface GigabitEthernet6
no ip address
interface GigabitEthernet6.1
encapsulation isl 1
no ip redirects
bridge-group 1
interface GigabitEthernet6.60
encapsulation isl 60
no ip redirects
standby 60 preempt
interface GigabitEthernet7
no ip address
interface GigabitEthernet7.1
encapsulation isl 1
no ip redirects
bridge-group 1
interface GigabitEthernet7.70
encapsulation isl 70
no ip redirects
standby 70 preempt
no ip address
channel-group 1
interface BVI1
no ip redirects
router eigrp 200
network 172.25.0.0
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 172.25.d.e
bridge 1 protocol ieee
bridge 1 route ip
end
3750 switch config:
bridge irb
hold-queue 300 in
interface GigabitEthernet1/0/1
no switchport
standby 10 ip 172.25.f.g
standby 10 preempt
bridge-group 1
no shutdown
interface GigabitEthernet1/0/2
no switchport
standby 20 ip 172.25.f.g
standby 20 preempt
bridge-group 1
no shutdown
interface GigabitEthernet1/0/3
no switchport
standby 30 ip 172.25.f.g
standby 30 preempt
bridge-group 1
no shutdown
interface GigabitEthernet1/0/4
no switchport
standby 40 ip 172.25.f.g
standby 40 preempt
bridge-group 1
no shutdown
interface GigabitEthernet1/0/5
no switchport
standby 50 ip 172.25.f.g
standby 50 preempt
standby 50 priority 105
bridge-group 1
no shutdown
interface GigabitEthernet1/0/6
no switchport
standby 60 ip 172.25.f.g
standby 60 preempt
standby 60 priority 105
bridge-group 1
no shutdown
interface GigabitEthernet1/0/7
no switchport
standby 70 ip 172.25.f.g
standby 70 preempt
standby 70 priority 105
bridge-group 1
no shutdown
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
channel-group 1 mode on
no shutdown
interface BVI1
standby 1 preempt
exit
bridge 1 protocol vlan-bridge
bridge 1 route ip
ip routing
router eigrp 200
network 172.25.0.0
no auto-summary
exit
ip classless
end
186
