Etherchannel bundle
Recently we have done the etherchannel bundle of mixed media(copper & fiber). Can any one suggest, is there any problems.
Since we are facing a problem i.e
error message
"%GLBP-4-DUPADDR: Duplicate address x.y.z.2 on vlan 'A' sourced by xxxx.yyyy.zzzz
Re: Etherchannel bundle
Hi Bhushan,
Etherchannel bundle of mixed media(copper & fiber) will work fine as long as the ports capability and configuration is fine.
The error message which you are getting is related to GLBP configuration.
Have a look at the explaination from one of the doc
Duplicate address [IP_address] on [chars], sourced by [enet]
Explanation
The IP address in a GLBP message received on the interface is the same as the IP address of the router. This condition may be because of misconfiguration or because of a malfunctioning switch.
Recommended Action
Check the configurations on all the GLBP routers, and ensure that any switches you have are functioning properly.
Ankur
*Pls rate helpfull post
Totally agree with you Ankur
307
