11-21-2006 01:08 AM - edited 03-05-2019 12:56 PM
Hello All,
Need assistance, am trying to configure etherchannel between a Cisco3725 and Cisco Catalyst 3550. Can't get it working with my existing config below. Please help.
Physical Connection
3725 F0/0 ---> 3550 F0/1
3725 F0/1 ---> 3550 F0/2
===== ROUTER ======
int po1
hold-queue 300 in
int po1.1
encap dot1q 1 native
ip address 10.0.0.1 255.255.255.0
int f0/0
channel-group 1
int f0/1
channel-group 1
===== SWITCH =====
int po1
switchport trunk encap dot1q
switchport mode trunk
hold-queue 300 in
int f0/0
channel-group 1 mode on
int f0/1
int vlan 1
ip address 10.0.0.2 255.255.255.0
11-21-2006 01:22 AM
Check the requirements on http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_example09186a00800ef797.shtml#req
Seems like 37xx don't support trunkig and FEC at the same time on the "routed" interfaces. But you don't use any additional vlan besides vlan 1, so why bother?
11-21-2006 04:44 AM
Thanks for the reply! :) I also tried this config (see below), without 802.1q trunking, still no luck... i only configured a single vlan for the purpose of testing the FEC.
===== ROUTER ======
int po1
hold-queue 300 in
int f0/0
channel-group 1
int f0/1
channel-group 1
===== SWITCH =====
int po1
hold-queue 300 in
int f0/1
int f0/2
int vlan 1
11-21-2006 04:58 AM
i think the ip address of the po1 on the switch should be 10.0.0.2 255.255.255.0 should be in the same subnet.
Mahmood
11-21-2006 05:13 PM
Thanks for your reply.
I did initially tried this before posting, to be able to assign an ip to po1 interface, i would have to use the "no switchport" command... but whenever I the config below, it gives me error:
"Command Rejected: Not a convertible port"
=== SWITCH ===
int po1
no switchport
