Etherchannel config
ltrasmundi
I keep getting the following message when I bring up the 2nd trunk. It works with only the one trunk up. Does anyone know why i am getting this message. It only works with one trunk up, does not matter which one. As soon as I bring up the 2nd trunk I get the following message.
1d01h: %EC-5-DONTBNDL: Gi3/2 suspended: incompatible partner port with GigabitEt
hernet3/1
hernet3/1
glen.grant
You would have to post the config , you something configured wrong . Each side must have the exact same parameters . Is this a straight etherchannel or is it trunked also ? Are you bringing up both ports at the same time . Maybe if you post we can see it.
The two ports in an ether channel should be identical in speed/duplex settings. if its a layer 2 trunk, then the allowed vlans should be same.
Please check again and rate this if it helps...
Thanks..
*aijaz*
