04-03-2014 03:04 PM - edited 03-07-2019 06:59 PM
I just purchased 3 2960S-48FPD-L switches. I also ordered one (soon to be 2) 3850-24t-L. I am currently looking at purchasing an NM 4-1G module to go with the 3850. My intent in this is to configure etherchannels from the 3- 2960's front SFP ports, to the 4 port module I am getting for the 3850. I just want to make sure it is possible?
Wayne
04-03-2014 04:10 PM
yes it is possible.
regards
rc
04-03-2014 04:27 PM
As long as the SFP you are going to use on both ends you should be fine, therefore just make sure of that.
