Webcast-Catalyst9k
Etherchannel for Qos in differernt queue and threshold LAN ports
Is it ok to form an etherchannel on 6500 with qos enabled and in differnent queue and threshold on LAN ports?
1 REPLY
Re: Etherchannel for Qos in differernt queue and threshold LAN p
Normally, etherchannels need all ports to have the same QoS structure and the etherchannel will not form if there is a difference, but you can disable this checking with the command:
no mls qos channel-consistency
HTH - plz rate useful posts (not just mine!)
Andrew.
165
