03-11-2009 03:31 PM - edited 03-06-2019 04:32 AM
We have 2 C3750 switches trunked together using an Etherchannel (2 trunk links). In the config it doesn't show what type of load-balnce we are using eg scr-mac scr-ip? How can I find this out?
03-11-2009 03:47 PM
Simply type 'show etherchannel load-balance'
It is set to source-mac by default.
03-11-2009 05:25 PM
the default always src-mac
you can change it useing the following command:
Switch(config)#port-channel load-balance ?
dst-ip Dst IP Addr
dst-mac Dst Mac Addr
src-dst-ip Src XOR Dst IP Addr
src-dst-mac Src XOR Dst Mac Addr
src-ip Src IP Addr
src-mac Src Mac Addr
good luck
if helps Rate
