Etherchannel is not balancing traffic (WS-6504)
I have an infrastructure ACE module Active, Standby, connected between two 6504 switch. The switches are interconnected with a port channel with two links.
When a particular link flap (interface G2/48), the ACE become Active-Active for a moment.
I think this behavior is not correct, the etherchannel apears not balancing trafic, does anybody know what could be the cause of this error?
This is the configured port channel in both ends.
interface Port-channel140
switchport
switchport trunk allowed vlan 500
switchport mode trunk
interface GigabitEthernet2/47
switchport
channel-group 140 mode on
end
interface GigabitEthernet2/48
switchport
end
GigabitEthernet2/47 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 0027.0dc5.799a (bia 0027.0dc5.799a)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseT
  input flow-control is off, output flow-control is off
  Clock mode is auto
  Last input 00:00:33, output 00:00:35, output hang never
  Last clearing of "show interface" counters 24w2d
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     768513 packets input, 147706892 bytes, 0 no buffer
     Received 767683 broadcasts (764857 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     8144099 packets output, 680213673 bytes, 0 underruns
  Hardware is C6k 1000Mb 802.3, address is 0027.0dc5.799b (bia 0027.0dc5.799b)
  Clock mode is auto
  Last input 00:00:05, output 00:00:48, output hang never
  5 minute input rate 6000 bits/sec, 10 packets/sec
  5 minute output rate 529000 bits/sec, 277 packets/sec
     154696025 packets input, 11341248236 bytes, 0 no buffer
     Received 148727439 broadcasts (764903 multicasts)
     1433721501 packets output, 321032915942 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
185
