Etherchannel L3 from 6509 to 3750 doesn't work
npservice
Hi, I have six Gigabit ports in Channel.
I tried mode On, Lacp,Pagp, Etherchannel go up but some links flapping and comunication is broken.
6509:
interface Port-channel2
ip address 192.12.47.254 255.255.255.252
ip sap listen
ip ospf cost 2
interface GigabitEthernet9/19
no ip address
no cdp enable
channel-protocol pagp
channel-group 2 mode desirable
interface GigabitEthernet9/20
no ip address
no cdp enable
interface GigabitEthernet9/21
no ip address
no cdp enable
interface GigabitEthernet9/22
no ip address
no cdp enable
interface GigabitEthernet9/23
no ip address
no cdp enable
interface GigabitEthernet9/24
no ip address
no cdp enable
3750:
interface Port-channel1
ip address 192.12.47.253 255.255.255.252
ip sap listen
ip ospf cost 2
interface GigabitEthernet3/0/7
no ip address
no cdp enable
channel-group 1 mode desirable
interface GigabitEthernet3/0/8
no ip address
no cdp enable
interface GigabitEthernet3/0/9
no ip address
no cdp enable
interface GigabitEthernet3/0/10
no ip address
no cdp enable
interface GigabitEthernet3/0/11
no ip address
no cdp enable
interface GigabitEthernet3/0/12
no ip address
no cdp enable
Log from 6509:
Oct 18 18:03:47: %EC-SP-5-L3DONTBNDL1: Gi9/21 suspended: PAgP not enabled on the
remote port.
Why?
glen.grant
config looks correct . I would look for physical layer issues on the flapping ports . Also on the 3750 I would use crossover cables and turn off mdix on the ports , we have seen weird stuff with mdix on occasions. I usually use the parameter of non-silent after the desirable statement , I know it works because we have a 3750 to 6509 trunk set this way and have never had a problem.
Hi, I tried to set non-silent command under port-channel configuration but It remain down.
I'm using Sfp 1000Sx to connect 3750 to 6509 and Mdix is disabled.
What Ios version do you have in your Switch?
Some ports are Up, some ports are Down:
remote port. Oct 18 18:03:47: %EC-SP-5-L3DONTBNDL1: Gi9/21 suspended: PAgP not enabled on the
remote port.
chris.baird
I believe both ends of the channel need to be in the same channel-group.
hth
