Etherchannel limitations WS-X4548-GB-RJ45
jackwikinski
Is anyone aware of any limitation on building an etherchannel on the abovementioned linecard, when bundling more than one port on the same card?
The 4506 is using a 6L-E supervisor engine 12.2(54)SG1.
If it's done on a 6500 with a WS-X6148-GE-TX linecard it affectivley can only reach 1gb throughput.
TIA.
Jack.
krahmani323
Level 3
Level 3
Hello Jack,
After going through the documentation I did not find any limitation information on this WS-X4548-GB-RJ45 (just like we could find for WS-X6148-GE-TX)...
I would just pay attention to the distribution of the Etherchannel ports across the different ASIC ports group in the card (as per the 8-to-1 oversubscription) of this classic module WS-X4548-GB-RJ45 ==> Capacity of 6 Gbps (full duplex) connections to the central forwarding engine
WS-X4548-GB-RJ45V:
• Bandwidth is allocated across six 8-port groups, providing 1 Gbps per port group
============Other informaitons on the subject are ============
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/hardware/installation/guide/78-14409-08/01intro.html
Specification Summary - Table 3 - Port Information for Line Cards
4 The amount of oversubscription can be controlled by varying the number of ports used at 1000 Mbps. All ports can use Gigabit EtherChannel or IEEE 802.3ad for high-speed interconnection applications
Table 4. Product Specifications
EtherChannel technology
• Gigabit EtherChannel: All 1000 Mbps ports
• 10 Gigabit EtherChannel: All 10Gbps ports
• IEEE 802.3ad (Link Aggregation Control Protocol): All 1000 Mbps ports
• Port Aggregation Protocol (PagP): Yes
• Number of ports per tuple: 8
• EtherChannel and IEEE 802.3ad technology across line cards: Yes
Hope that helps.
Kind regards.
Karim
krahmani323
Level 3
Level 3
Hello Jack,
WS-X4548-GB-RJ45V:
Hope that helps.
Kind regards.
Karim
Thanks very much Karim.
Regards.
Jack.
