Webcast-Catalyst9k
EtherChannel Load Balancing
Hi all, just a question I'd like to have confirmed if possible.
We are running Etherchannel between 2 6500's, and have a back-up
running over it from one server to another as such:
Switch 1 <-4 port etherchannel-> Switch 2
Server 1 <- back-up traffic -> Server 2
So it's always traffic from a server on 1 switch to a server
on the other switch, so always same source and destination. I've done the
show channel hash command on both switches and it always chooses port 1/2
for the traffic, given the same source/destination on each switch.
So my belief is that any of the available options for load-balancing
being source or dest mac, source/dest IP address or even layer 4 port would give
the same result in that it is always the same source and destination and i imagine
the back-up stream would follow the same source/dest ports in the stream and so
will always go over the same single port in the channel, can anyone please confirm
that I'm on the right track there ? And that it will always use only one port ?
Many Thanks !
Steve.
Re: EtherChannel Load Balancing
You are correct indeed. Traffic between two hosts always utilizes the same path as long as it is available. I believe this implementation was partly chosen to prevent the channel causing out-of-sequence packets.
Conclusion: An etherchannel is only effective when you run traffic between a large amount of nodes (which is normally always the case)
On the other hand: regarding performance, you have little to gain from using more than one link while the throughput will still be limited by the host adapter's capacity. I assume that we are talking all gigabit links here for both the channel and the servers.
Leo
Hi Leo,
Thanks for the reply, the etherchannel links are all gig's and the servers in question are also on gig interfaces. We run a lot of other connections through these core switches, it's just this one that got up to 40% utilization so was more noticeable.
Thanks again for clearing that up for me.
Steve.
771
