Community Member
Etherchannel load balancing
Does both ends off the channel have to use the same load balancing methode? Is the methode used in this case based on the side the traffic originates from? What is the preffered setup between a 6513 and a 3020?
Thanks for any help.
1 REPLY
Purple
Re: Etherchannel load balancing
No you can use whatever you want on each end.
127
