Community Member
EtherChannel media question.
Can an EtherChannel be formed using different media type ports? I.E. Can I use GigE and GBIC of SFP porrts together in a Port Channel?
Maurice
Hall of Fame Super Silver
Re: EtherChannel media question.
Hello Maurice,
this should be possible until all links are set to use the same speed and duplex.
So a suggestion could be that of hardcoding speed 1000 duplex full on electrical ports if they are 10/100/1000.
Probably it is not considered best practice but it should be possible.
Hope to help
Giuseppe
Community Member
Thank you! This really helps me out immensely!
133
