Etherchannel on 3560 switch to Broadcom Gigabit Cards
I was wondering if anyone has setup a Server with Broadcom NIC for Etherchannel. What method of Load balanacing did you use? Did you have to configure the switch
1 REPLY
Re: Etherchannel on 3560 switch to Broadcom Gigabit Cards
You have to use LACP between the server NIC's and the 3560 switch ports. Make sure that you server NIC driver support the port-bundeling and also have the load-balancing mechanism. Please find the link below on configuring switchports for ether-channel using the LACP :
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3560/12225sed/scg/swethchl.htm
HTH,Please rate if it does.
-amit singh
666
