EtherChannel on private-vlan ports 3560G
I am trying to configure LACP EtherChannel on a Cat-3560G.
I connected several server to different Cat-3560G switches on isolated privat-vlan-port. I have one backup-system that I connect on promiscuous port on one single Cat-3560G. All devices are in the same L2 domain. So far this works like expected.
Now I am trying to configure LACP EtherChannel for the backup-system to increase throuput. I wanted to to like in the Cisco Document ID: 98469. Unfortunately EtherChannel configuration is not possible on private-vlan-port.
Any workaround for this problem?
Thank you
Re: EtherChannel on private-vlan ports 3560G
You need to configure the channel on a non-private-vlan. Thats the only work around I know. You can always restrict the access with an VLAN ACL.
Ok. I will use ACL instead of private VLAN. Unfortunately It's not as simple as privat VLAN and less secure (?)
Well, You can get almost as secure as you want it. You could use a VACL
Basically you break it down like this:
access-list TRAFFIC permit (traffic incoming and outgoing to the VLAN)
than create you vlan access-map
vlan access-map TEST 10
match address TRAFFIC
action forward
vlan access-map TEST 20
action drop
vlan filter-list TEST vlan 100 (number of you vlan)
In the first access-map that referances the access-list TRAFFIC you permit all your traffic here. This traffic can be inside the vlan itself too.
example - permit tcp host 10.205.0.1 host 10.205.0.2 - In the same subnet
So thi is a good way to secure traffic inside the vlan you apply to that port. You have full control over what allowed inside and outside with this VACL
Here a good read:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_44_se/configuration/guide/swacl.html
363
