etherchannel portfast
Can i use spantree portfast on etherchannel links?
i am trying to configure etherchannel between dell esxi host and a 6509
interface Port-channel1
switchport
switchport access vlan 120
switchport mode access
no ip address
shutdown
interface GigabitEthernet5/5
switchport
no ip address
spanning-tree portfast
channel-group 1 mode on
interface GigabitEthernet5/4
switchport
no ip address
is this ok configuration?
channel-group 1 mode has several options
active     Enable LACP unconditionally
  auto       Enable PAgP only if a PAgP device is detected
  desirable  Enable PAgP unconditionally
  on         Enable Etherchannel only
  passive    Enable LACP only if a LACP device is detected
what option should i use?
Re: etherchannel portfast
Personally, I wouldn't do it. If for some reason your etherchannel breaks and spanning tree sees each link as individual links instead of the port-channel as a whole, you're asking for trouble.
As far as your modes, I'd select active or desirable on both ends. "On" mode doesn't use a negotiation protocol, but Active (LACP) or Desirable (Pagp) uses negotiation for the other end. The Active and Desirable modes actively try to form an etherchannel, whereas the Passive and Auto modes listen for the negotiation but don't try to actively form an etherchannel.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
hi
I configured the port channel but show etherchannel 1 summary is showing this
SE6509#show etherchannel 1 summary
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
1      Po1(SD)         LACP      Gi5/4(I)   Gi5/5(I)
why is the Portchannel in a SD state? It means its down?
Yes, it's down. Are the ports physically up? Have you configured the other side?
I also noticed that the port channel interface is shut...
HTH,
John
Purple
  The device on the far end has to be setup as an LACP negotiated etherchannel also for it work . Talk to the people who support the dell.
the other end is a esxi host. from he documentation, I have setup the nics to route based on IP hash but still the port channel is in a down state
Hall of Fame Super Blue
Tony
It's not to do with the load balancing method ie. IP hash it is far more fundamental than that. The ESXi host is not forming an etherchannel with the switch.
You need to check the host end.
Jon
651
