03-03-2008 02:38 PM - edited 03-05-2019 09:31 PM
Hi, could some one confirm the following.
If I have an EtherChannel that consists of 2 physical circuits, is a single data transfer able to use both physical circuits or is it limited to just one circuit?
Thanks James.
03-03-2008 02:45 PM
James:
Etherchannel is used to bundle multiple physical inter-switch ethernet links together so that the switches see them as only ONE logical link, instead of 3, 4 or 5 (up to 8) separate physical links. This will allow you to use the bandwidth of those redundant links without having them blocked by STP.
Example:
Switch A and switch B are connected to each other via one dot1q trunk. If you add another dot1q trunk, STP will block that trunk from forwarding user-traffic because it does not allow redundant links that carry the same vlan traffic to exist. It may cause a loop. If you configure ehterchannel on both switches, however, the switches' STP process will not block any additional trunks because they will all be placed in one etherchannel channel group and be seen as only one link.
If so, please rate my post
Victor
03-03-2008 02:49 PM
James
Generally speaking a single data transfer in one direction will only use one of the available links as etherchannel load balances flows across it's links. What it load balances on can be src/dst mac address, src/dst IP address and port numbers but not all switches support all types of load balancing.
Jon
03-03-2008 02:51 PM
James:
Here is an excellent Cisco link that elaborates on how traffic is load balanced across an etherchannel.
If so, please feel free to rate my posts.
