12-19-2013 01:35 PM - edited 03-07-2019 05:10 PM
Netapp server is connected to switch 6500 via trunk.
I configured a portchannel but it showing as down.take a look ar below output..
interface Port-channel248
description Netapp-server-1 po248
switchport
switchport trunk allowed vlan 903
switchport mode trunk
switchport nonegotiate
no ip address
no shut
interface GigabitEthernet3/33
description server-1
switchport
no ip address
speed 1000
udld port aggressive
spanning-tree portfast
channel-group 248 mode active
no shut
interface GigabitEthernet4/33
description cnndcfasp002a-e5d
switchport
no ip address
speed 1000
no shut
Switch-6500#sh etherchannel summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
Number of channel-groups in use: 5
Number of aggregators: 5
Group Port-channel Protocol Ports
248 Po248(SD) LACP Gi3/33(I) Gi4/33(I)
#sh etherchannel detail
Group: 248
Group state = L2
Ports: 2 Maxports = 16
Port-channels: 1 Max Port-channels = 16
Protocol: LACP
Minimum Links: 0
Ports in the group:
Port: Gi3/33
Port state = Up Sngl-port-Bndl Mstr Not-in-Bndl
Channel group = 248 Mode = Active Gcchange = -
Port-channel = null GC = - Pseudo port-channel = Po248
Port index = 0 Load = 0x00 Protocol = LACP
Flags: S - Device is sending Slow LACPDUs F - Device is sending fast LACPDUs.
A - Device is in active mode. P - Device is in passive mode.
Local information:
LACP port Admin Oper Port Port
Port Flags State Priority Key Key Number State
Gi3/33 SA indep 32768 0xF8 0xF8 0x321 0x7D
Age of the port in the current state: 0d:02h:04m:58s
Port: Gi4/33
Local information:
Gi4/33 SA indep 32768 0xF8 0xF8 0x421 0x7D
Port-channels in the group:
Port-channel: Po248 (Primary Aggregator)
Age of the Port-channel = 7d:16h:30m:16s
Logical slot/port = 14/3 Number of ports = 0
Port state = Port-channel Ag-Not-Inuse
Protocol = LACP
Any one please let me know what is the issue here...
Gautham
12-19-2013 02:54 PM
Its because it doesn't see LACP messages on the other side or its connected to two different devices. Or to the same devices but with a LACP link and a different LACP link or a not LACP link
I've had that problem so many times.
12-19-2013 03:00 PM
Thanks for the reply...
So the problem might be on NETAPP server right ??? i mean netapp server need to configure with same LACP configs that i have used on 6500 right ???
12-19-2013 03:12 PM
Exactly, the 6500 config is fine, probably the NETAPP is not active or passive and it's just ON that won't work
show lacp 248 neighbor will show if you have a neighbor and if the LACP id is the same on both ports
Core1#sh lacp 2 neighbor
Flags: S - Device is requesting Slow LACPDUs
F - Device is requesting Fast LACPDUs
A - Device is in Active mode P - Device is in Passive mode
Channel group 2 neighbors
Partner's information:
Partner Partner LACP Partner Partner Partner Partner Partner
Port Flags State Port Priority Admin Key Oper Key Port Number Port State
Gi1/7/10 SA bndl 32768 0x0 0x1 0x11A 0x3D
Gi2/7/10 SA bndl 32768 0x0 0x1 0x31D 0x3D
cheers
12-19-2013 04:13 PM
i see below ouput..
So what does below output mean ??
switch-6500#sh lacp 248 neighbor
Channel group 248 neighbors
Gi3/33 SP indep 0 0x0 0x0 0x0 0x0
Gi4/33 SP indep 0 0x0 0x0 0x0 0x0
12-19-2013 11:25 PM
indep Means independed state (not on lacp etherchannel)
bndl bundled (that is good)
cheers
04-29-2017 09:19 PM
i have too this problem with port-channel
I am using 2 port channel 14&123
14 is connected to 2 ports(4/1 and 4/3)
123 is connected to 4 ports(2/32-33,2/35,2/38)
But here is the problem is in port-channel 14 i have facing problem with one port is bonding and second port is going to independent, Why this happened, I want port-channel 14 same like port channel 123, Both ports have to come in banding not independent
Gi4/1 SA bnd1
Gi4/3 SP indep
14 Po14(SU) LACP Gi4/1(P) Gi4/3(I)
123 Po123(SU) LACP Gi2/32(P) Gi2/33(P) Gi2/35(P) Gi2/38(P)
