Community Member
etherchannel using catOS and a combination of gig copper and gig fiber
All, I cannot find documentation that says for catos, when using etherchannel (lacp) if one can use both fiber and copper ports in the same bundle keeping duplex and speeds the same? please advise
thx- larz
1 REPLY
Hall of Fame Super Blue
Re: etherchannel using catOS and a combination of gig copper and
Yes you can mix and match media types as long as the speed and duplex is the same. Attached is a link to all 6500 etherchannel restrictions.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/7.x/configuration/guide/channel.html#wp1032805
Jon
288
