Etherchannel will not come up on Catalyst 6509
I am connecting to core switches together via etherchannel on their 10G ports
I AM Running s72033-ipservices_wan-vz.122-18.SXF9.bin on THE 2 6509s for some reason the 10G ports on core b will not come up. Config listed below. I do a no shut and it still says shut down
Core A
interface TenGigabitEthernet9/1
switchport
switchport mode trunk
switchport nonegotiate
no ip address
channel-group 1 mode on
interface TenGigabitEthernet9/2
switchport
no ip address
interface Port-channel1
description Etherchannel link to Core B
switchport
no ip address
Core b
description Etherchannel link to Core A
switchport
shutdown
no ip address
switchport
shutdown
no ip address
description Etherchannel Port to Core A
switchport
no ip address
1 ACCEPTED SOLUTION
Re: Etherchannel will not come up on Catalyst 6509
Hi Keith,
Do the trunks come up as standalone trunks without configuring etherchannel?
Please try to do this first of part of the troublesghooting process.
This way we can isolate if this is an Etherchannel problem or it is something different.
Please inform us about your experience.
Istvan
Hall of Fame Super Blue
Your physical ports on Core b - they are in a "shutdown" state. Is this a typo ?
Jon
No Jon that is the crux of my problem when I go into the inteface and do a no shut it stays shut and thats what the current running config looks like I am scractching my head trying to figure out why.
Blue
Hi:
For EtherChannel to come up, make sure:
All ports are configured with the same speed and duplex settings.
All ports are in the same vlan.
The same vlans are being allowed on each of the trunk ports you would like to make part of the channel.
Both switches are in the same VTP domain.
Check those things first.
Victor
Hi Keith,
Istvan
Istvan,
I did what you suggested and even went further I reseated the card then I took the etherchannel config off the card. It came up as a stand alone trunk. So then I redid the etherchannel config and it came up.
Blue
Keith:
So are you saying its up now?
If I had ot take an educated guess, I dont think reseating the cards fixed anything. I would say it was bouncing the etherchannel config.
VL
VL
Yes it is up and I agree with you that was just as a sanity check since I couldn't get the physical interface to unshut it kept saying it was shut down and I wanted to make sure it was recognizing the xenpak.
Keith
Blue
Besides intuition, this is why I say that bouncig the etherchannel probably fixed it. Check it out...
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_tech_note09186a00800949c2.shtml#wait
Victor
394
