01-31-2007 06:32 AM - edited 03-05-2019 02:05 PM
Can you run etherchannel with spanning tree enabled ?
01-31-2007 06:34 AM
in etherchannel you are making the logical bundle of the multiple channel so here they are not working as the seperate redundant link... so there is no issue of the loop prevention...
regards
Devang
01-31-2007 06:35 AM
So there is no need to enable spanning tree ?
01-31-2007 06:39 AM
EtherChannels "bundle" ports. You'd do this to increase bandwidth. SO just like single ports Ethernet Channesl can also create loops, and can run STP as a "collective" i.e not for each port within the channel.
01-31-2007 07:24 AM
do you have a example config of this. thanks for your help
01-31-2007 07:55 AM
hi,
look at this link: http://www.cisco.com/warp/public/473/127.html
here you will more clear your fundamental...
rate the post if it helps
regards
Devang
