Etherchannel
Hello everyone,
My question is can I bundle the two fastethernet interface of a router 2811 to create an etherchannel, like in the case of a switch?
If yes, please explain.
Re: Etherchannel
I think its not possible with onboard fe interfaces which are l3 only. I havenot tried setting up the l3 etherchanne using the ports though...might be worth trying..
i know its possible with the use of Ether switchmodules on the router.
Re: Etherchannel
When I issue the command "channel-group 1", the router says "channel-group 1 is not configure", which tells that somehow the channel can be configure.
Any help, please
Super Bronze
Re: Etherchannel
Thanks a bunch joseph, that solved the problem
Purple
Re: Etherchannel
The command is probably there in case you have installed like hwic switch modules in which you can channel those interfaces .
132
