Highlighted
Community Member
Etherchannnel with NIC team issue
I am having difficulty implementing what should be an easy task.
I have a single ESXi 6.5U1 host with 2 NICs teamed in a single vSwitch. The load balancing is set to “route based on IP hash”. As part of my troubleshooting I have also disabled beacon probing (Net.MaxBeaconsAtOnce=0).
The NIC team connects to a single Cisco 2960 switch. Both interfaces are up and the host is reachable.
To avoid Mac flapping on the switch (due to the NIC teaming), I am trying to configure an Etherchannel on the switch. My config below (both switch ports are configured identically):
interface GigabitEthernet0/6
switchport trunk native vlan 1000
switchport mode trunk
channel-group 2 mode on
end
interface GigabitEthernet0/7
end
interface Port-channel2
end
EtherChannel Load-Balancing Configuration:
        src-dst-ip
Group Port-channel Protocol Ports
2 Po2(SU) - Gi0/6(P) Gi0/7(P)
The post channel comes up on the switch but the ESXi host is not reachable. As soon as I shut one of the ports, the comms is restored. I can’t figure out what I am doing wrong – any ideas?
1 ACCEPTED SOLUTION
Community Member
Re: Etherchannnel with NIC team issue
Got it sorted.
Facepalm.
The load balance algorithm set on the vSwitch does not propagate to the management network.
https://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=1022751
Thanks for confirming my etherchannel config on the switch is correct and guiding me to look on the ESXi side!
Silver
I would recommend rechecking your ESXi network settings :)
You might have missed something. Check if your team has the correct adapters as members
Additionally, your members SHOULD not have any vSwitch configured on one of them. Take note that your vSwitch should now be on the port-group defining your NIC team
Community Member
Thanks, I have attached my server side config - I can't see anything wrong :(
Note that for these sreenshots, I have removed the Etherchannel on the switch to indicate that the correct interfaces form part of the NIC team (remember that with the Etherchannel configured, I can only reach the ESXi host if I shut one interface on the Cisco switch).
Can you spot anythign issue here? Thanks again
VIP Purple
sounds like something is off on the server side , your switch config is correct cehck this guide may help you
https://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=1004048
Community Member
Thanks - I have added my server config above (can't spot the problem unfortunately).
I have worked through the article you posted already and I have configured my environment as close as possible to this guide ... still no luck however.
VIP Purple
have you tried LACP instead as an option see if its having an issue being forced on
Community Member
Yes, with LACP (mode access) the the Etherchannel does not come up at all. I believe this might be because I am using a vSwitch - not a distributed switch (not an option in my environment).
VIP Purple
Ok Cool so no lacp , says in the video too do not use beacon with ip hash load balancing looks like thats setup on your screenshots ? maybe im wrong im not a server guy
Community Member
Yeah beacon probing is disabled - screenshot attached
VIP Purple
rest of it looks spot on watching the video for server side , yours matches their config too
did you try without the native vlan just in case as a test incase if its the cause , try standard trunk
Community Member
Thanks Mark - I tried that (no native vlan defined) but with the same result - no comms to the host.
Community Member
Got it sorted.
Facepalm.
Silver
Told ya it's on your ESXi ;)
VIP Purple
ah good stuff
VIP Purple
If your able to , mark your post as answered as it will help other people find it if there run into the same issue , its not allowing me mark your post above as answered
Community Member
Will do. Thanks again for taking the time to help!
296
