Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
ethernet and ip headers
Hi all, i know this is a very basic question, but can anyone tell me what the ethernet header is, and what it contains and used for, and also the same for the ip header ?
Re: ethernet and ip headers
Have a look here
http://www.wildpackets.com/support/compendium/manual_appendices/nxA1_packets
You should get all these details by googling on the internet :-)
Narayan
when the router receives the packet and needs to forward it, I have seen that it needs to rebuild the header, is this the layer 2 ethernet header, ie next hop mac address ?
The header would differ based on the connection the router has..
If the router needs to forward a packet out its interface which is serial, then it would build a HDLC or PPP header, similarly FR header for frame-relay. If it is ethernet, then it would be a ethernet header with the next-hop mac addresss as the destination MAC
Narayan
371
