EVM-HD-8FXS-DID
hello
I need set up the max EM-HDA-6FXO, how many can to be installed in router 3825.
ebreniz
Level 6
Level 6
The Cisco High-Density Extension Module operates in any network module (NM) or enhanced network module (NME) slot on the Cisco 3825 and Cisco 3845 integrated services routers.
Two (2) , EVM-HD Modules Supported on Cisco 3825 router.
Also refer the following link :
http://www.cisco.com/en/US/prod/collateral/modules/ps2617/prod_qas0900aecd8016c487_ps5855_Products_Q_and_A_Item.html
Hello. thanks for reply. this is helpful.
For 3825 are suppoted 1 and for 3845 are supported 2 in slots NM o NME, Check table 3..
