Excel template for auto switch configuration?
bmckean
Does anyone know if there is an excel template that has basic router or switch configuration commands where all you do is type in the value or option then it exports into text or csv? I'm not interested in gui interfaces.
see attached..
It probably does not exist b/c of changes IOS version as well as differences b/t models but I'm just curious.
Bernie
Leo Laohoo
Have you tried using Smartports Macros?
Configuring Smartports Macros
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_44_se/configuration/guide/swmacro.html
This is dependent on the model of your switch. This is applicable to the low-end switch up to the high-end ones.
To verify, just type in the command "show parser macro brief".
Hope this helps you.
Leo Laohoo
I've created a small macro for you to use.
macro name MyMacro
hostname $host
clock timezone PST -8
username admin password 7 $password
ip domain-name $dom-name
# Keywords: $host
# Keywords: $password
# Keywords: $dom-name
If you need to invoke this macro, do the following:
conf t
#macro global apply MyMacro $host MYSWITCH $password Cisco $dom-name acme.cayote.com
Does this help?
Yes, Thank you both for your help.
Please rate if this is successful. Thanks.
