03-19-2008 01:13 PM - edited 03-05-2019 09:51 PM
I thought I knew how to exclude an addres..
but im not familiar with the SDM statements found in the config..
If I wanted to exclude 192.168.22.99..how would i confiugre this?
ip dhcp excluded-address 192.168.22.99 ?
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 192.168.22.1 192.168.22.10
ip dhcp pool sdm-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
ip dhcp pool sdm-pool1
import all
network 192.168.22.0 255.255.255.0
dns-server 192.168.1.27
default-router 192.168.22.1
netbios-name-server 192.168.119.2 192.168.117.15
netbios-node-type h-node
Solved! Go to Solution.
03-20-2008 07:12 AM
Per the link I posted:
"Manually configured DHCP option parameters override imported DHCP option parameters"
03-19-2008 06:04 PM
Yup, is that simple :)
HTH,
__
Edison.
03-19-2008 06:42 PM
thx!
I was doing research regarding the "import all"
command. Does this have to do with the
far end router? What exaclty does this command do?
This document makes it sound like it is getting configuration from the "core" router
http://www.cisco.com/warp/public/105/dhcp_ser.html
And is sdm simply a default statement when configuring dhcp?
03-19-2008 07:59 PM
"import all" is used when you need to bring options from another DHCP router into your current router instead of typing them one by one.
http://www.cisco.com/en/US/docs/ios/12_3/ipaddr/command/reference/ip1_i1g.html#wp1078583
I'm not familiar with SDM since I do all my configs at the CLI therefore I can't tell you what default statement would SDM use.
__
Edison.
03-20-2008 06:29 AM
Thx Edison,
Since we are bringing in options from another DHCP router with the "import all" command-does
this void out what is configured on this particular router.
ip cef
import all
lease 0 2
import all
03-20-2008 07:12 AM
