Expanding Router Ports on 2811
The 2811 only has two Ethernet router ports. Is it possible to install a HWIC-4ESW and configure one or more of its four ports as router ports?
1 REPLY
Hall of Fame Super Bronze
Re: Expanding Router Ports on 2811
Do you mean LAN ports ? Yes.
http://www.cisco.com/en/US/products/ps5855/products_qanda_item0900aecd8016c026.shtml
"Q. What devices can you connect to the Cisco EtherSwitch HWICs?
A. You can connect many devices to the Cisco EtherSwitch HWICs, including:
? A PC or workstation
? An IP telephone
? Cisco Aironet? or third-party 802.11a/g-based access points or bridges
? A port on Cisco Catalyst switch or any third-party switch
? A Cisco CallManager
? Any device with a 10BASE-T/100BASE-TX interface
? Any device with a 10BASE-T/100BASE-TX interface with 802.3af-based in-line power requirements
? A hub or workgroup hub
Q. What is Ethernet switching?
A. Each Ethernet interface on the Cisco EtherSwitch HWICs can connect to a single workstation, server, or hub through which workstations or servers connect to the network. On a typical Ethernet hub, all ports connect to a common backplane within the hub and all devices attached to the hub share the bandwidth of the network. If two stations establish a session that uses a significant level of bandwidth, the network performance of all other stations attached to the hub is degraded. To reduce degradation due to collisions in a shared LAN, the Cisco EtherSwitch HWIC treats its Ethernet interface as a separate collision domain."
212
