Community Member
Expansion Module - N5K-M1008
Can I know what SFP connector are compatible with this expansion module.
Thank you.
1 ACCEPTED SOLUTION
Re: Expansion Module - N5K-M1008
I understand your question better now.
•     N5K-M1404 provides 4 10G SFP+, and 4 Fiber Channel 1/2/4G SFP based uplink connections. The 10GE ports are encryption capable.
•     M5K-M1600 provides 6 10G SFP+ based uplink connections.
•     N5K-M1008 provides 8 1/2/4G Fiber Channel, SFP based uplink connection.
This means the N5K-M1008 will not support GLC-T= or any other Ethernet SFP. The Nexus5000 switch will support GLC-T=/GLC-SX-MM=, but these modules will not. The fiber-channel expansion ports only support the FC transceivers listed here:
Cisco DS-SFP-FC4G-SW     4-Gbps Fibre Channel SW SFP, LC (for Fibre Channel expansion module ports)
Cisco DS-SFP-FC4G-LW     4-Gbps Fibre Channel LW SFP, LC (for Fibre Channel expansion module ports)
Cisco DS-SFP-FC8G-SW     8-Gbps Fibre Channel SW SFP+, LC (for Fibre Channel expansion module ports)
Cisco DS-SFP-FC8G-LW     8-Gbps Fibre Channel LW SFP+, LC (for Fibre Channel expansion module ports)
I hope that helps, please rate if it does.
-Tim
You can use any of these:
GLC-T(=) 1000BASE-T SFP
GLC-SX-MM(=) GE SFP, LC connector SX transceiver
GLC-LH-SM(=) GE SFP, LC connector LX/LH transceiver
SFP-GE-T(=) 1000BASE-T SFP, Extended Temperature Range
SFP-GE-S(=) GE SFP, LC connector SX transceiver, with Digital Optical Monitoring (DOM) and Extended Temperature Range
SFP-GE-L(=) GE SFP, LC connector LX/LH transceiver, with Digital Optical Monitoring (DOM) and Extended Temperature Range
DS-SFP-FC4G-SW(=) 4Gbps Fibre Channel-SW SFP, LC
DS-SFP-FC4G-LW(=) 4Gbps Fibre Channel-LW SFP, LC
DS-SFP-FC8G-SW(=) 8Gbps Fibre Channel-SW SFP+, LC
DS-SFP-FC8G-LW(=) 8Gbps Fibre Channel-LW SFP+, LC
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/data_sheet_c78-461802.html
Rate if that helps!
Community Member
Hello Tim,
I saw the page that you give me in your post, but I read this information:
I have the N5K-M1008 Expansion Module that has 8 port 1/2/4 Gbs.
And my question is:
This expansion module just support this kind of SFP connector that the table said (DS-SFP-FC4G-SW or LW) or the N5k-M1008 Expansion Module can support the another kind of SFP connector that the switch support such as SFP-SX-SM or GLC-T or any that the page said that is compatible with the Nexus 5000.
Thank you.
-Tim
1951
