01-14-2010 09:01 AM - edited 03-06-2019 09:17 AM
I've done a traceroute and I get the following output:
traceroute 10.9.64.51
Tracing the route to 10.9.64.51
1 10.10.51.70 0 msec
10.10.51.145 0 msec
10.10.51.70 4 msec
2 10.10.51.73 104 msec 104 msec 100 msec
3 10.9.64.51 104 msec 100 msec 104 msec
My question is why does hop 1 have three hops? Can anyone suggest a reason.
Dan
01-14-2010 09:06 AM
Tracing the route to 10.9.64.511 10.10.51.70 0 msec
10.10.51.145 0 msec
10.10.51.70 4 msec
3 10.9.64.51 104 msec 100 msec 104 msecMy question is why does hop 1 have three hops? Can anyone suggest a reason.
Dan
Dan
Because you have 2 equal cost paths to the same destination on that router. So if you do a "sh ip route 10.9.64.51" on the router you should see 2 routes, one with the next-hop of 10.10.51.70 and one with the next-hop of 10.10.51.145.
Jon
01-14-2010 09:18 AM
Jon,
Ahhh ic. a few more questions then,
1) I'm using eigrp how is that I have two routes installed in my routing table, don't I have to activate "variance" before it's used?
2) Since there are two paths with equal costs then why are there three ip's showing up? and how does it decide which of the two ip's it will use to send the data through?
Thanks again
Dan
01-14-2010 09:25 AM
dan_track wrote:
Jon,
Thanks again
Dan
Dan
1) variance is only used for unequal cost paths. If the paths are equal cost they will both be installed in the routing table.
2) As Milan alluded to, it depends on what load-balancing you have ie. per-packet or per-destination (the default). The router simply alternates between the 2 routes either on per-packet or per-destination.
Jon
01-14-2010 09:35 AM
ad 1) EIGRP is providing equal-cost load-balancing by default.
see http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094820.shtml
ad 2) read this article for details:
http://www.cisco.com/en/US/tech/tk827/tk831/technologies_tech_note09186a0080094806.shtml
BR,
Milan
01-14-2010 09:21 AM
just for a curiosity:
It would be interesting to compare with a traceroute ouput to the same destination started on a PC withing the LAN connected to the first router.
If I remember my CEF readings correctly, per-session load balancing is applied by default.
But per-packet always on packets sent from a router itself!
So you should see just one hop (either 10.10.51.70 or 10.10.51.145) in the traceroute output when running a traceroute from a PC to the same destination.
BR,
Milan
01-15-2010 04:07 AM
Here's the output from a pc connected to the switch:
tracert -d 10.9.64.51
Tracing route to 10.9.64.51 over a maximum of 30 hops
1 <1 ms <1 ms <1 ms 10.45.64.254
2 <1 ms <1 ms <1 ms 10.45.66.253
3 1 ms <1 ms <1 ms 10.10.51.145
4 102 ms 102 ms 102 ms 10.10.51.73
5 102 ms 102 ms 102 ms 10.9.64.51
If I keep repeating it I keep seeing the following: 10.10.51.145. Is this to do with Jon's suggestion about per-packet or per-destination? Are there any documents about this feature? Is this feature related to CEF?
Dan
01-15-2010 04:27 AM
yes, that's caused by the per-destination load sharing applied by default on packets coming through the router.
See details in
http://www.cisco.com/en/US/tech/tk827/tk831/technologies_tech_note09186a0080094806.shtml#whatis
http://www.cisco.com/en/US/products/hw/modules/ps2033/prod_technical_reference09186a00800afeb7.html
http://www.cisco.com/en/US/docs/ios/12_0s/feature/guide/pplb.html
BR,
Milan
