Extended Vlans
mahesh-gohil
I am attaching here one of my cisco 3550 "sh ver" and "sh vtp status" kindly let me know does this switch support extended vlan (upto 4094)
Mahesh
You can't configure extended vlans from vlan database config mode.
From config mode
JPR-MPL-COR-SWH-78(config)# vlan 3000
Configuring Extended-Range VLANs
When the switch is in VTP transparent mode (VTP disabled), you can create extended-range VLANs (in the range 1006 to 4094 for any switch port commands that allow VLAN IDs). Enter the vlan vlan-id global configuration command to access config-vlan mode and to configure extended-range VLANs. The VLAN database configuration mode (that you access by entering the vlan database privileged EXEC command) does not support the extended range.
Jon
6 Replies 6
Jon Marshall
Yes it will as long as you are in VTP transparent mode which you are from your vtp status output.
Jon
Ya
but it shows Maximum VLANs supported locally : 1005
How can I go beyond this
DTE-RHY-F00-SW1#sh vtp status
VTP Version : 2
Configuration Revision : 0
Number of existing VLANs : 9
VTP Operating Mode : Transparent
VTP Domain Name : PPTE-POD
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
VTP Traps Generation : Enabled
MD5 digest : 0xDC 0xE4 0x3D 0x04 0x2C 0xFE 0xD2 0xA5
Configuration last modified by 172.16.15.7 at 3-9-93 22:11:57
DTE-RHY-F00-SW1#sh vlan
VLAN Name Status Ports
1 default active
5 OBM_MST_vlan active
206 WIN-XP-SVR active
251 Rydale_Hse active Fa0/1, Fa0/2, Fa0/3, Fa0/4, Fa0/5, Fa0/6, Fa0/7,
Fa0/10, Fa0/11, Fa0/12, Fa0/13, Fa0/14, Fa0/15,
Fa0/18, Fa0/19, Fa0/20, Fa0/21, Fa0/22
253 Ex_FITZ_SUITE3 active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
3190 test active <------
** Edit - excerpt from 3550 Cisco config doc
Supported VLANs
The Catalyst 3550 switch supports 1005 VLANs in VTP client, server, and transparent modes. VLANs are identified with a number from 1 to 4094. VLAN IDs 1002 through 1005 are reserved for Token Ring and FDDI VLANs. VTP only learns normal-range VLANs, with VLAN IDs 1 to 1005; VLAN IDs greater than 1005 are extended-range VLANs and are not stored in the VLAN database. The switch must be in VTP transparent mode when you create VLAN IDs from 1006 to 4094.
So "VTP only learns normal-range VLANs". That is why you see the figure 1005 in sh vtp status but the switch will support extended vlans.
Jon
correct
now see
JPR-MPL-COR-SWH-78#sh vtp status
VTP Version : 2
Number of existing VLANs : 26
VTP Domain Name : bharti
VTP Traps Generation : Disabled
MD5 digest : 0x4F 0xF9 0x6E 0x31 0xFB 0x7B 0x19 0x8C
Configuration last modified by 202.123.39.222 at 0-0-00 00:00:00
JPR-MPL-COR-SWH-78#vla
JPR-MPL-COR-SWH-78#vlan data
JPR-MPL-COR-SWH-78#vlan database
% Warning: It is recommended to configure VLAN from config mode,
as VLAN database mode is being deprecated. Please consult user
documentation for configuring VTP/VLAN in config mode.
JPR-MPL-COR-SWH-78(vlan)#vla
JPR-MPL-COR-SWH-78(vlan)#vlan 3000
% Invalid input detected at '^' marker.
From config mode
Jon
Hello Jon,
I understood that we can only do the extended VLAN configuration in transparent mode,if we are using vtp version 2.
But is there any specific reason that we cant configure it in Server mode?
Thanks in advance!!!
