Extending DC LAN over Transparent ISP circuit
Hello all,
See the attached design.
My ISP says that it deliver me 2 cables in each point completelly transparent.
They sold me 1 Gbps circuit plus a 1Gbps failover circuit in the cloud.
I need to extend the LAN over the cloud.
In each DC i have 2 3750G in stackwize which will connect each other to 2 3750v2 from the ISP (not represented in design).
I was thinking to configure EtherChannel between the DCs, but i realize that maybe will not work cause one of the links will be on failover mode.
Pure trunking between DCs, i guess it wont work much fine for the same reason.
The reason i think it wont work, is because of not getting 2 physical links between both ends.(Somewhere in the middle, it will be only one physical link)
Any ideas for this type of configuration?
Should i ask the ISP to terminate the Etherchannel on the ISP equipment of each site ?
Best Regards,
Bruno Petrónio
  • LAN Switching and Routing
151
