Silver
EzVPN using DVTIs & QoS
I am configuring an EzVPN client to use Dynamic VTIs; the config fragments are:
class-map match-all VOICE
match ip dscp ef
class-map match-any CALL-SETUP
match ip dscp af31
match ip dscp cs3
class-map match-any INTERNETWORK-CONTROL
match ip dscp cs6
policy-map 256-UPSTREAM
class CALL-SETUP
bandwidth percent 2
class INTERNETWORK-CONTROL
bandwidth percent 5
class VOICE
priority 128
class class-default
fair-queue
random-detect
policy-map SHAPER-256-UPSTREAM
class class-default
shape average 192000
service-policy 256-UPSTREAM
interface FastEthernet0/0
ip address dhcp
ip access-group EXT-IN-PLUS in
duplex auto
speed auto
crypto ipsec client ezvpn TEST
service-policy output SHAPER-256-UPSTREAM
interface FastEthernet0/1
ip address 10.199.0.1 255.255.254.0
duplex auto
speed auto
no keepalive
crypto ipsec client ezvpn TEST inside
interface Virtual-Template1 type tunnel
no ip address
ip mtu 1408
ip tcp adjust-mss 1368
tunnel mode ipsec ipv4
I've discovered that the counters displayed in the "show policy-map interface ..." command only increment when the service-policy is attached outbound on the physical outside crypto interface. The examples I've seen on CCO suggest applying the service-policy on the virtual-template interface, but the counters don't increment and the QoS policies are not enforced. Where should the service-policy be applied in a DVTI EzVPN Client configuration?
182
