Community Member
fa 0/1 to be used as back up interface
I need to configure my 2nd ethernet inteface to be an backup interface for the primary one as a backuplink which should come up when the first link has some physical issues. Can i use backup interface command for this , what will be the ip needed to configure for the backup interface (ip unnumbered primary interface)
Thanks for any suggestions
Community Member
Re: fa 0/1 to be used as back up interface
if you talking about switch it will be done by using etherchannel either layer 2 or 3
but if you work with router you can bridge the two interfaces.
rate if it is help you.
Community Member
Iam talking about a router. I want to have one ethernet as a stand by for the other and start forwarding traffi when the first one fails.
Will bridging help in this case.
Thanks for your response
Community Member
look in router you can't asign two interfaces with the same network if they work as layer 3 so by bridging them you just asign the configuration to the ogical interface created and the two phyiscal interfaces work as switch
Hi Parthi
You can check out the tracking feature available in the router to achieve your requirement here.
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a008042fbeb.html
regds
288
