FabricPath between MSTP and RSTP
Tommy LE BALCH
Hi all,
is it possible to interconnect 2 sites in fabricpath with one domain in MSTP for the first site and an other domain in RSTP for the second site ?
Peter Paluch
Hello Tommy,
That should be possible, however, the MSTP and RSTP will not really interact with each other.
The FabricPath region appears as a single bridge with no other bridges behind it to any STP/RSTP/MSTP switch connected to it. BPDUs are not carried or tunnelled through the FabricPath region, rather, the STP is terminated at the edge port of a FP-enabled switch. This way, the FP region effectively isolates the STP islands from each other.
Read more about this interaction in the following document:
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9402/white_paper_c11-687554.html#wp9000376
Best regards,
Peter
OK thank you, we will try it soon.
I'll come back here for the results.
