Webcast-Catalyst9k
Facebook Forum - Catalyst Security (DHCP Snooping, DAI, IP source guard)
Live chat with Cisco expert, Judhajit Ghosh on Catalyst Security (DHCP Snooping, DAI, IP source guard)
June 19th, 2012
Here's an opportunity to make your Network secure by learning about Catalyst Security - DHCP Snooping, DAI, IP source guard. DHCP snooping is a feature that provides network security by filtering untrusted DHCP messages.Facebook_Forum_Template_040_2.png
It is designed to keep networks safe from rogue DHCP servers, thus preventing from any security threat in a DHCP environment
Dynamic ARP inspection is a feature that ensures that only valid ARP requests and replies are relayed.
IP source guard is a security feature that restricts IP traffic on nonrouted, Layer 2 interfaces by filtering traffic
based on the DHCP snooping binding database and on manually configured IP source bindings.
Our expert, Judhajit is an engineer at Cisco who specializes in LAN Switching and has certifications in CCNA and CCNP(BCMSN).
Date: June 19
6:00 AM EDT (New York; UTC -5 hrs)
8:00 PM EST (Sydney; UTC +10 hrs)
12:00 PM CEST (Berlin; UTC +1 hr)
3:30 PM IST (India; UTC +5 hrs)
To RSVP Click Here
What is Facebook Forum?
Facebook forums are online conversations, held at a ore-arranged time on our Facebook page. It gives you an opportunity to interact with a live Cisco expert and get more information about a particular technology, service or product.
How do I participate?
On the day of the event, go to our Facebook page http://www.facebook.com/CiscoSupportCommunity
Like us on Facebook
Everyone's tags (2)
1 REPLY
Re: Facebook Forum - Catalyst Security (DHCP Snooping, DAI, IP s
Summary of the live Facebook forum on Catalyst Security (DHCP Snooping, DAI, IP source guard)
Cisco Online Support Community
We have our first question .....Are these 3, DHCP Snooping, DAI, IPSG related anyway?
Judhajit Ghosh
Glad that you asked.The answer is yes. All these three are layer 2 security features and is interrelated. For
example, the Dynamic Arp inspection will inspect and validate ARP packets based on the DHCP Snooping binding table. DAI will discard ARP packets with invalid IP-to-MAC address bindings, and will generate a log message in the switch.
Some intoduction to these:
Judhajit here comes the second question from another user - What is the ARP packet rate limiting in this context?
Judhajit Ghosh
The default rate is 15 pps on untrusted interfaces and unlimited on trusted interfaces. One has to realize, that
there is a 15 pps limit for ARP on any DAI untrusted interface, which if exceeded will move the port to err-disable...... Then We can use the command of: "errdisable recovery cause arp-inspection interval 30" to have a port automatically recover after 30 seconds when this occurs.... Hope that answers the question...
Is IP Source guard supported on 6500 switches?
Judhajit Ghosh
Glad that you asked. Yes, they are, but with limitations. IP source guard is supported on PFC 3 or later versions
with Release 12.2(33)SXH and later releases.
Tejbir Batth
In Dhcp snooping...will the snooping database be only on the switches where host are connected or would it be also be seen on intermediate switches through which requests passed....
Judhajit Ghosh
The snooping database/ binding table will be formed on the switch which is directly connected to the hosts....provided that snooping is enabled.... :-D..... hope that clarifies
Can I find the rouge DHCP server after enabling these features?
Judhajit Ghosh
No. These features are there to prevent the rouge machines becoming the DHCP server. So, you need to know where your legitimate DHCP server is and trust only the path towards it.
Is there any limitation of the binding table?
Judhajit Ghosh
The DHCP snooping database/ binding table stores max. 8,000 bindings
My DHCP is working but not DHCP snooping. What are the things I can check?
Judhajit Ghosh
Good question. Here are some checks you can do..
>Have you have enabled the DHCP snooping globally
>Have you enabled the DHCP snooping for the concerned Vlans
>You have trusted the correct interfaces
The above will be three basic checks you can do. All of the above information can be found from one command output (show ip dhcp snooping)
There are other debugs as well, like "debug ip dhcp snooping packets/events" which might give you additional
information, but any debug command has to be handled carefully as the same might be CPU intensive...
Will all CAT6K and CAT4K device support these features?
Judhajit Ghosh
As far as I remember, All will, except cat4000 running CATOS. Cat4000 Sup 1 & 2 only support CatOS, while any
greater Sup engine like Sup 2+, 3, 4, 5 will support IOS. Adding to that, any XL switch does not support these  features.
We have a user asking this question.......Could you please tell me about database agent?
Judhajit Ghosh
The database agent is for the safety of the binding table......Because other features use the DHCP Snooping
Database, it is a good idea to offload it to a remote server on your network. This allows the database to be
recovered after a power failure. Without this agent, the bindings established by DHCP snooping are lost upon reload, and connectivity is lost as well. The database agent stores the bindings in a file at a configured location.
To enable the Database Agent:
ip dhcp snooping database {ftp:// | tftp:// | rcp:// | flash: | http://}
Judhajit Ghosh
For a detailed understanding of these features on 6500 platform you can refer the following link:-
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SY/configuration/guide/dhcp_snooping.html
the feature and the commands remains more or less the same on all platforms....
For more questions and answers on this topic, please visit the live forum at
https://supportforums.cisco.com/thread/2155254
To visit the actual forum that took place on Facebook visit here:
https://www.facebook.com/CiscoSupportCommunity/posts/276354552463649
571
