Facing issue in "Show ip route" command in GNS3
tayyabarif8632
Dear Support Engineers,
I am new in cisco field, i make a simple topology and below is the configuratons:
R1#show ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
Serial1/0                  12.1.1.1          YES manual up                    up
Serial1/1                  13.1.1.1           YES manual up                    up
Loopback0               1.1.1.1             YES manual up                    up
R1#show ip route
Gateway of last resort is not set
C    1.0.0.0/8 is directly connected, Loopback0
     12.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C       12.0.0.0/8 is directly connected, Serial1/0
C       12.1.1.2/32 is directly connected, Serial1/0
     13.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C       13.0.0.0/8 is directly connected, Serial1/1
C       13.1.1.3/32 is directly connected, Serial1/1
This output is confusing for me, it is veriably subnetted. I search alot on google to get the solution but failed, now looking forward to you.
I want this result as:
R1#show ip route
Your quick response will be very appreciated.
Thanks & Best Regards
Tayyab Arif
John Blakley
When you're using ppp encapsulation, the default is to use a peer route which is where you see your /32. On your serial interface, enter "no peer neighbor-route", shut and no shut your interface and the /32 should be gone.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
7 Replies 7
devils_advocate
Level 7
Level 7
The IP addresses on the Serial Interfaces are Class A so have a default subnet mask of 255.0.0.0 which is a /8 which is shown in the Routing Table.
If you do a #show ip route connected you should just see the connected routes:
C   1.1.1.1/32  is directly connected, Loopback0
C   12.1.1.0/30  is directly connected, Serial0/3/0
C   13.1.1.0/30  is directly connected, Serial0/3/1
Dear Davils,
I find the same issue again, result is mentioned below
R1#show ip route connected
Can you post the full config of R1 ?
Jon
Kindly find the configurations
R1#show running-config
Building configuration...
Current configuration : 1189 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 5
ip subnet-zero
no ip icmp rate-limit unreachable
ip cef
ip tcp synwait-time 5
no ip domain lookup
interface Loopback0
ip address 1.1.1.1 255.0.0.0
interface Serial1/0
ip address 12.1.1.1 255.0.0.0
encapsulation ppp
serial restart-delay 0
clock rate 64000
interface Serial1/1
ip address 13.1.1.1 255.0.0.0
encapsulation ppp
clock rate 64000
ip classless
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
Tayyab
John is spot on. Could you mark the answer provided by John as correct so others who may have the same issue will be able to find the answer here.
Jon
John Blakley
HTH,
John
Issue solved.
Thanks John Blakley....!
