failed POST in loopback test
i've a problem on a port of a switch 3550.
i attach the output of the telnet session:
SW3550A(config)#int fast 0/35
SW3550A(config-if)#no shut
Fa0/35 can't be brought up because it failed POST in loopback test
SW3550A#show post
Stored system POST messages:
POST: CPU Buffer Tests : Begin
POST: CPU Buffer Tests : End, Status Passed
POST: CPU Interface Tests : Begin
POST: CPU Interface Tests : End, Status Passed
POST: Switch Core Tests : Begin
POST: Switch Core Tests : End, Status Passed
POST: CPU Interface 2nd Stage Tests : Begin
POST: CPU Interface 2nd Stage Tests : End, Status Passed
POST: CAM Subsystem Tests : Begin
POST: CAM Subsystem Tests : End, Status Passed
POST: Ethernet Controller Tests : Begin
POST: Ethernet Controller Tests : End, Status Passed
POST: Loopback Tests : Begin
looped-back packet not received on controller 3, channel 11
POST: Loopback Tests : End, Status Passed
SW3550A#
CAN YOU EXPLAIN ME THE PROBLEM?
i don't find documentation about this problem.
THANKS FOR YOUR HELP.
fcostalunga
Re: failed POST in loopback test
POST failures are bad news. This is almost certainly a hardware problem. Retry the boot without anything connected to the port. If the problem remains (as I assume that will be the case) this means that you have a faulty interface.
Leo
thenks for your help.
I wan't to know if exist a document that explain this problem.
Can you have a link of cisco.com that treat this argument?
thanks
FCostalunga
1028
