04-29-2014 07:27 PM - edited 03-07-2019 07:16 PM
Hi All,
Need your help in undergoing an Activity.
I need to do replacement for failed Supervisor Engine 720 10GE (standby) on Cisco 6509 in production.
We have not to do a Hot Swap, but it has to be done after powering down the Chassis.
I think after powering down the Chassis if the Old Working Sup Module comes as active then we can copy the config. from Active (Old Sup) to Standby (new one) after copying of the IOS file from Active to Standby and rebooting the Standby.
But, if in case new Sup Module comes as Active and the old Sup Module go standby and IOS being different in both Sup Modules, I need to know how to restore the Services?
Please help to reply ASAP.
Thanks in advance to all.
04-29-2014 07:40 PM
In a 6509 when you have 2 sups configured in SSO mode, the primary sup is in slot 5 and the stand-by is in slot 6. If you are replacing the stand-by (slot 6) after rebooting the switch slot 5 will again be the primary and the config will sync from primary to stand-by.
Make sure you have the same exact IOS in both sups.
04-29-2014 07:43 PM
Thank you so much Reza for the reply.
This is to update you Sup Module in Slot 5 has failed and Slot 6 is the Active Sup now.
New Sup has been RMA'ed but may not have the same IOS as the other Working Sup Module in SLot 6.
Also, are you confirmed that always Slot 5 Sup becomes the Active one because as per me there is no restriction as such like this.
Thanks.
04-29-2014 08:12 PM
If you have 2 sups in slot 5 and 6 with both sups having the same exact IOS with SSO configured and if you reboot the chassis with both sups in it, slot 5 will be the primary.
04-29-2014 08:16 PM
ok thanks.
New Sup has not the same IOS as the other Working Sup Module in SLot 6.
What can be the Steps to be followed for the Sup Module replacement, if we need to power down the Chassis during Module Replacement?
