failing IP communication across the network with 3750x
Hi!
I'm facing a very odd problem. A week ago I've installed a 3750x on a client.
 On it, was connected, a Lan2Lan fiber channel(with IP associated directly to
 the interface) and a MPLS link(over a Cisco 2901) interconnecting a branch,
 and several HP v1910 L2 swtiches.
By the day of the activation, everything works great. I have at this first moment,
configured static routes with IP SLA on the L2L link and, with higher cost on the
MPLS due the larger bandwidth of the L2L. It worked very well, and the tests of
redundancy were ok.
My problems started a couple of days after. First, I've lost the IP communication
with the L2 switches from the stations, but, from the 3750x, they still were
accessible(both telnet and ping).
And now, there's another problem. Because of a previous design, there are two
gateways configured across the network, all the stations and some servers,
use as the default gateway the IP 10.31.1.1, and several servers and other
appliances where configured with the gateway 10.31.1.2. So, as a workaround,
I had configured both address on the 3750x, the 10.31.1.1/16 as primary IP
and the 10.31.1.1/16 as secondary IP, both are on the VLAN 1 yet, as all the
devices. All the stations, servers and appliances are configured with
this /16 mask. And, it is working.
The problem is, every time that the communications between the branches
is changed from one link to the another, on some servers and appliances, after the IP SLA
take away the route, the communications only occurs if I manually change the
default gateway on the servers/appliance to the other IP, and, get back to the
previous one.
Does anyone saw something like that?
Everyone's tags (6)
70
