FAILOVER FEATURE ON CAT 500 24 PORT SWITCH
Hi ,,Pls i need advice on how i can deploy a failover solution on cat 500 switch .I have 2 isp connections terminated on the switch every thing is up and running but i need to know if i can implement an intelligent feature on a cat 500 switch that enables it failover the another link when one of the links is down.using a router is not an option as the company i'm implementing for might not be able to afford
Bronze
Re: FAILOVER FEATURE ON CAT 500 24 PORT SWITCH
It does not support the failover solution mean 2 isp connection. For the further details and configuration for the ce500 switch follow the URL :
http://www.cisco.com/en/US/products/ps6545/products_configuration_example09186a00806da6c9.shtml
i have cat 500, which i reseted by pressing the setup bottom, the problem is that when i connect it to my laptop lan port or PCI, it doesnt pull the default gateway. as i dont have the device manager cd
231
