Community Member
Failover for L3 Switch
In our setup we are using two 3550 series as the distribution layer switch,
all the uplink from the layer2 switch is connected in that and also voice gateway is connected on it
We need redunancy over the Layer3 switch.
which is the best way of deploying it whether we can go for HSRP or VRRP
Please suggest me for the above issue and give me some step by step command to configure the same .
Vinoth
1 REPLY
Hall of Fame Super Blue
Re: Failover for L3 Switch
Hi Vinoth
Are your 3550 switches connected with a L2 trunk. Assuming they are here is an example of config on 3550 switches for a vlan with HSRP
3550_1
int vlan 10
ip address 192.168.5.2 255.255.255.0
standby 10 ip 192.168.5.1
standby 10 priority 110
standby 10 authentication cisco
standby 10 preempt
3550_2
int vlan 10
ip address 192.168.5.3 255.255.255.0
standby 10 priority 100
Do this for each of your vlans on the 3550 switches that you want to run HSRP for.
The default-gateway on your clients in vlan 10 would be 192.168.5.1.
Jon
263
