05-19-2010 01:07 AM - edited 03-06-2019 11:09 AM
We inserted a new module with 48 rj45 ports in a 4500 with just one supervisor module. We have two 4500, and we tried the new model in the other 4500 and it´s working properly and giving a OK status. Furthermore, the module´s LED status is green. We saw that there are 8 ports (from 17 to 24) that are in faulty state, so probably this is the cause for the faulty state for the module.
We tried already a Hw reset, replace/insert again the module...
We are almost sure that it can be a Hw failure but will help if someone had the same trouble.
We are getting the following results different commands:
show module :
Mod Ports Card Type Model Serial No.
7 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAXXXXXXXH
M MAC addresses Hw Fw Sw Status
7 3435.34E8.33e3 to 8843.e1c8.ae1f 2.5 Faulty
show diagnostic result module 7 detail
module 7: SerialNo :JAXXXXXXXH
Overall diagnostic result: MINOR ERROR
Test results: (. = Pass, F = Fail, U = Untested)
___________________________________________________________________________
1) linecard-online-diag ------------> F
Error code ------------------> 4 (DIAG_PARTIAL_FAILURE)
Total run count -------------> 1
Last test execution time ----> Nov 24 2009 08:22:22
First test failure time -----> Nov 24 2009 08:22:22
Last test failure time ------> Nov 24 2009 08:22:22
Last test pass time ---------> n/a
Total failure count ---------> 1
Consecutive failure count ---> 1
Slot Ports Card Type Diag Status Diag Details
7 48 10/100/1000BaseT (RJ45) Partial Failure Stub
Partial Failure Port
Detailed Status
. = Pass U = Unknown
L = Loopback failure S = Stub failure
P = Port failure
E = SEEPROM failure G = GBIC integrity check failure
Ports 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
Ports 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
S S S S S S S S . . . . . . . .
Ports 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
2) online-diag-tdr:
Port 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
U U U U U U U U U U U U U U U U U U U U U U U U
Port 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
Error code ------------------> 0 (DIAG_SUCCESS)
Total run count -------------> 0
Last test execution time ----> n/a
First test failure time -----> n/a
Last test failure time ------> n/a
Total failure count ---------> 0
Consecutive failure count ---> 0
Thanks in advanced.
Solved! Go to Solution.
05-19-2010 04:37 AM
Verify the IOS version supports the card . If so then the card is faulty . You have an asic that is not passing POST . Ports on the cards run thru asics which covers 8 ports so there are 6 six asics on a 48 port card , one of them is not passing the POST. Get it replaced .
05-19-2010 01:16 AM
What is the IOS?
05-19-2010 01:20 AM
Sorry,
I forgot to add that detail:
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICESK9-M), Version 12.2(50)SG, RELEASE SOFTWARE (fc4)
Thank you.
05-19-2010 01:31 AM
Can't find any bugs related to your issue. Safe bet is to RMA it.
05-19-2010 01:49 AM
Thanks leolaohoo,
We are going to open a RMA, but how could be we sure if they will have to replace/repair the whole 4500? Or if just a part is having a failure?
Carolina
05-19-2010 03:17 AM
Is there another spare slot where you can insert this?
05-19-2010 04:43 AM
Hello leolaohoo,
There was no spare slot, but we remove another module (was not in use at the moment) and the card is working properly there.
glen.grant,
We have installed in another 4500 with exactly the same IOS another card (and also this one, while troubleshooting) and it´s working properly, so it seems like it´s not a card or IOS problem.
Thanks.
05-19-2010 04:44 AM
Glenn's right. ASIC can sometimes come good. Otherwise the ASIC will deteriorate in time.
05-19-2010 04:37 AM
05-27-2010 03:49 AM
Thanks for your answers,
Finally the processor engine was damaged, and we had to replace it. Now everything is working fine.
07-19-2012 03:04 AM
Hi Carolina,
I am experiencing same issue with one of my customer place. unfortunately they are having only 1 4507R+E chassis and 1 4548 module. how you identified this was issue with Processor Engine. however i have replaced the module 4548 as well even after getting the same error ...!! but they are having redudant X45-SUP6L-E tried by removing each at one time with no luck. pls
Its running with
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASE-M), Versio
n 12.2(53)SG2, RELEASE SOFTWARE (fc1)
Current bootup diagnostic level: minimal
module 7: SerialNo : JAE160902N2
Overall Diagnostic Result for module 7 : MINOR ERROR
Diagnostic level at card bootup: minimal
Error code ------------------> 1 (DIAG_FAILURE)
Last test testing type ------> n/a
Last test execution time ----> Jul 19 2012 06:36:12
First test failure time -----> Jul 19 2012 06:36:12
Last test failure time ------> Jul 19 2012 06:36:12
Total Failure All ports
Detailed Status
P = Port failure
S S S S S S S S S S S S S S S S
--More--
2) online-diag-tdr:
Error code ------------------> 3 (DIAG_SKIPPED)
Detailed Status
##################################################33
