Community Member
Feb 23 09:59:00.714 IST: %C4K_EBM-4-HOSTFLAPPING: Host 00:11:92:83:B6:00 in
Can any one suggest me how resolve the problem of Mac-address flapping ,as per the scenerio is concern My Switch (SW1 and SW2 ) are conncted to Customers switches (Cusw1 sand Cusw2) ,now My Sw1 having inbuilt Mac-address is reflecting in other 2 ports of Cutomer Switches .
Reflecting the error :- Feb 23 09:59:00.714 IST: %C4K_EBM-4-HOSTFLAPPING: Host 00:11:92:83:B6:00 in vlan 9 is flapping between port Gi7/12 and port Gi7/48"
Re: Feb 23 09:59:00.714 IST: %C4K_EBM-4-HOSTFLAPPING: Host 00:11
This sounds like it could either be a spanning tree issue or ports are flapping cause spanning tree to re-converge (possible downstream from your kit).
If you have no link up down errors on your kit I would ask your customer to check there's for any errors.
This MAC address is a cisco (MAC 001192 belongs to cisco), so I suspect this is the bridge ID of one of those switches.
Community Member
Dear Adam ,
Thanks for the response ,yes this Mac addres belong to Switch 3550 flash
Please find the error message getting in thr switches
VEL Core SW#sh logging
Syslog logging: enabled (0 messages dropped, 76 messages rate-limited, 0 flushes
, 0 overruns)
Console logging: level warnings, 218344 messages logged
Monitor logging: level notifications, 197 messages logged
Buffer logging: level debugging, 1303384 messages logged
Exception Logging: size (8192 bytes)
Count and timestamp logging messages: disabled
Trap logging: level debugging, 1303379 message lines logged
Logging to 10.77.28.15, 788712 message lines logged
Log Buffer (4096 bytes):
Feb 23 09:59:15.350 IST: %C4K_EBM-4-HOSTFLAPPING: Host 00:11:92:83:B6:00 in vlan
Feb 23 09:59:30.083 IST: %C4K_EBM-4-HOSTFLAPPING: Host 00:11:92:83:B6:00 in vlan
Feb 23 09:59:44.731 IST: %C4K_EBM-4-HOSTFLAPPING: Host 00:11:92:83:B6:00 in vlan
Feb 23 10:00:01.763 IST: %C4K_EBM-4-HOSTFLAPPING: Host 00:11:92:83:B6:00 in vlan
9 is flapping between port Gi7/48 and port Gi7/12
Feb 23 10:00:16.600 IST: %C4K_EBM-4-HOSTFLAPPING: Host 00:11:92:83:B6:00 in vlan
Feb 23 10:00:31.224 IST: %C4K_EBM-4-HOSTFLAPPING: Host 00:11:92:83:B6:00 in vlan
Feb 23 10:00:45.904 IST: %C4K_EBM-4-HOSTFLAPPING: Host 00:11:92:83:B6:00 in vlan
Feb 23 10:01:00.533 IST: %C4K_EBM-4-HOSTFLAPPING: Host 00:11:92:83:B6:00 in vlan
Feb 23 10:01:15.189 IST: %C4K_EBM-4-HOSTFLAPPING: Host 00:11:92:83:B6:00 in vlan
Feb 23 10:01:32.605 IST: %C4K_EBM-4-HOSTFLAPPING: Host 00:11:92:83:B6:00 in vlan
Feb 23 10:01:44.401 IST: %C4K_EBM-4-HOSTFLAPPING: Host 00:11:92:83:B6:00 in vlan
Feb 23 10:01:59.054 IST: %C4K_EBM-4-HOSTFLAPPING: Host 00:11:92:83:B6:00 in vlan
Feb 23 10:02:16.702 IST: %C4K_EBM-4-HOSTFLAPPING: Host 00:11:92:83:B6:00 in vlan
Feb 23 10:02:31.450 IST: %C4K_EBM-4-HOSTFLAPPING: Host 00:11:92:83:B6:00 in vlan
Feb 23 10:02:46.055 IST: %C4K_EBM-4-HOSTFLAPPING: Host 00:11:92:83:B6:00 in vlan
Feb 23 10:03:00.611 IST: %C4K_EBM-4-HOSTFLAPPING: Host 00:11:92:83:B6:00 in vlan
Feb 23 10:03:15.315 IST: %C4K_EBM-4-HOSTFLAPPING: Host 00:11:92:83:B6:00 in vlan
Feb 23 10:03:30.043 IST: %C4K_EBM-4-HOSTFLAPPING: Host 00:11:92:83:B6:00 in vlan
Feb 23 10:03:44.656 IST: %C4K_EBM-4-HOSTFLAPPING: Host 00:11:92:83:B6:00 in vlan
Feb 23 10:03:59.368 IST: %C4K_EBM-4-HOSTFLAPPING: Host 00:11:92:83:B6:00 in vlan
This is the only mesage reflecting on thr ports.
Please recrt back for any other info
thnk
anubhuti
Hi Anabhuti
Gi7/12 and port Gi7/48 are trunks right? could you paste there config please.
Community Member
Hi Adam,
AS the configuration is at the csutomer end, and as per the security norms we cant provide u the whole config,but the those ports are trunk ports?
Anubhuti
Community Member
This is what I have seen in the past, the same MAC address is appearing on two devices.
Usually a customer has a programmable chip which has duplicate MAC address to re-write them on a network interface.
195
