FEX configuration on Nexus 7010
s-durando
I have a Nexus 7K running 5.1.(1a) with N2248T as Fabric Extender.
I had two ports on N7K-M132XP-12 module connected to N2248T.
In order to activated fex feature I issued the following commands :
install feature-set fex
feature-set fex
When I tried to configure the 10G ports as fabric-extender on N7K I had the following error:
Switch(config)# interface Ethernet10/27
Switch(config-if)# switchport
Switch(config-if)# switchport mode fex-fabric
ERROR: Ethernet10/27: Configuration does not match the port capability.
What is missing in my configuration?
Stefano
13 Replies 13
Jerry Ye
Since the configuration restriction said all port in the same port group will need to be in fex-fabric mode. What does the config for other ports in this port group looks like?
I am interested on port 25, 27, 29 and 31.
jerry
Ports in the same port-group have different configurations so I'm going to change the config in order to use 25,27,29,31 as fabric extender ports.
Thanks a lot
Stefano
Jerry,
I tried to configure all port 25, 27, 29 and 31 in fex-fabric mode but I have always the same message:
'Configuration does not match the port capability'
I also followed this documentation but it doesn't work.
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/interfaces/Configuring_the_Cisco_Nexus_2000_Series_Fabric_Extender_chapter1.html
Any suggestion?
Stefano
Can you post the config for all these 4 ports?
jerry
Jerry,
port config is very simple:
interface Ethernet10/25
  switchport
  switchport
interface Ethernet10/29
  switchport
interface Ethernet10/31
  switchport
Stefano
Try this:
interface e10/25 , e10/27 , e10/29 , e10/31
jerry
I tried but I had always the same message:
Switch(config)# interface e10/25 , e10/27 , e10/29 , e10/31
Switch(config-if-range)#   switchport mode fex-fabric
ERROR: Ethernet10/25, Ethernet10/27, Ethernet10/29, Ethernet10/31: Configuration does not match the port capability.
I tried also to configure port-channel before and then assign physical interfaces to port-channel
interface port-channel10
  switchport
  fex associate 101
Switch(config-if)# interface e10/25 , e10/27 , e10/29 , e10/31
Switch(config-if-range)# channel-group 10
command failed: port not compatible [Ethernet Layer]
** You can use force option to override the port's parameters
** (e.g. "channel-group X force")
** Use "show port-channel compatibility-parameters" to get more information on failure
Stefano
Can you post the following command output:
show run | i feature
show run int e10/25
show run int e10/27
show run int e10/29
show run int e10/31
show int e10/25 cap
show int e10/27 cap
show int e10/29 cap
show int e10/31 cap
show ver
show fex
jerry
Jerry,
you find below the info you requested.
Stefano
Switch# sh running-config | i feature
  allow feature-set fex
feature-set fex
feature telnet
feature udld
feature interface-vlan
feature hsrp
feature lacp
feature vpc
feature vtp
Switch# sh running-config interface ethernet 10/25
!Command: show running-config interface Ethernet10/25
!Time: Fri Dec  3 19:04:56 2010
version 5.1(1a)
  switchport
Switch# sh running-config interface ethernet 10/27
!Command: show running-config interface Ethernet10/27
!Time: Fri Dec  3 19:05:15 2010
version 5.1(1a)
  switchport
Switch# sh running-config interface ethernet 10/29
!Command: show running-config interface Ethernet10/29
!Time: Fri Dec  3 19:05:19 2010
version 5.1(1a)
  switchport
Switch# sh running-config interface ethernet 10/31
!Command: show running-config interface Ethernet10/31
!Time: Fri Dec  3 19:05:23 2010
version 5.1(1a)
  switchport
Switch# sh interface ethernet 10/25 capabilities
Ethernet10/25
  Model:                 N7K-M132XP-12
  Type (SFP capable):    10Gbase-SR
  Speed:                 10000
  Duplex:                full
  Trunk encap. type:     802.1Q
  Channel:               yes
  Broadcast suppression: percentage(0-100)
  Flowcontrol:           rx-(off/on),tx-(off/on)
  Rate mode:             dedicated/shared
  QOS scheduling:        rx-(8q2t),tx-(1p7q4t)
  CoS rewrite:           yes
  ToS rewrite:           yes
  SPAN:                  yes
  UDLD:                  yes
  Link Debounce:         yes
  Link Debounce Time:    yes
  MDIX:                  no
  Pvlan Trunk capable:   no
  Port Group Members:    25,27,29,31
  TDR capable:           no
  FabricPath capable:    no
  Port mode:             Routed,Switched
  FEX Fabric:            no
  dot1Q-tunnel mode:     yes
Switch# sh interface ethernet 10/27 capabilities
Ethernet10/27
  Speed:                 10000
  Duplex:                full
  Channel:               yes
  Rate mode:             shared
  CoS rewrite:           yes
  ToS rewrite:           yes
  SPAN:                  yes
  UDLD:                  yes
  Link Debounce:         yes
  MDIX:                  no
  TDR capable:           no
  FEX Fabric:            no
Switch# sh interface ethernet 10/29 capabilities
Ethernet10/29
  Type (SFP capable):    10Gbase-LR
  Speed:                 10000
  Duplex:                full
  Channel:               yes
  Rate mode:             shared
  CoS rewrite:           yes
  ToS rewrite:           yes
  SPAN:                  yes
  UDLD:                  yes
  Link Debounce:         yes
  MDIX:                  no
  TDR capable:           no
  FEX Fabric:            no
Switch# sh interface ethernet 10/31 capabilities
Ethernet10/31
  Type (SFP capable):    10Gbase-(unknown)
  Speed:                 10000
  Duplex:                full
  Channel:               yes
  Rate mode:             shared
  CoS rewrite:           yes
  ToS rewrite:           yes
  SPAN:                  yes
  UDLD:                  yes
  Link Debounce:         yes
  MDIX:                  no
  TDR capable:           no
  FEX Fabric:            no
Switch# sh version
Cisco Nexus Operating System (NX-OS) Software
TAC support:
http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_series_home.html
Copyright (c) 2002-2010, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under
license. Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or the GNU
Lesser General Public License (LGPL) Version 2.1. A copy of each
such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://www.opensource.org/licenses/lgpl-2.1.php
BIOS:      version 3.22.0
  kickstart: version 5.1(1a)
  system:    version 5.1(1a)
  BIOS compile time:       02/20/10
  kickstart image file is: bootflash:///n7000-s1-kickstart.5.1.1a.bin
  kickstart compile time:  12/25/2020 12:00:00 [11/04/2010 23:14:37]
  system image file is:    bootflash:///n7000-s1-dk9.5.1.1a.bin
  system compile time:     11/4/2010 11:00:00 [11/05/2010 00:25:15]
Software
Hardware
  cisco Nexus7000 C7010 (10 Slot) Chassis ("Supervisor module-1X")
  Intel(R) Xeon(R) CPU         with 4115812 kB of memory.
  Processor Board ID JAF1436ANLK
  Device name: DEA2
  bootflash:    2029608 kB
  slot0:        2074214 kB (expansion flash)
Kernel uptime is 1 day(s), 3 hour(s), 30 minute(s), 9 second(s)
Last reset at 148502 usecs after  Thu Dec  2 15:35:31 2010
  Reason: Reset Requested by CLI command reload
  System version: 5.1(1a)
  Service:
plugin
  Core Plugin, Ethernet Plugin
CMP (Module 5) ok
CMP Software
  CMP BIOS version:        02.01.05
  CMP Image version:       5.1(1) [build 5.0(0.66)]
  CMP BIOS compile time:   8/ 4/2008 19:39:40
  CMP Image compile time:  9/2/2010 19:00:00
CMP (Module 6) ok
CMP Software
Switch#  sh fex
  FEX         FEX           FEX                       FEX
Number    Description      State            Model            Serial
---       --------               Offline     N2K-C2248TP-1GE   JAF1436CCAH
The part highlighted in RED is the problem:
Ethernet10/25
  Speed:                 10000
  Duplex:                full
  Channel:               yes
  CoS rewrite:           yes
  ToS rewrite:           yes
  SPAN:                  yes
  UDLD:                  yes
  Link Debounce:         yes
  MDIX:                  no
  TDR capable:           no
  FEX Fabric:            no
My next questions are how old was this N7K and did you upgrade from a previous version to 5.1.1a? When you upgrade, did you upgrade the EPDL image also?
jerry
This N7K was shipped with NX-OS 5.0 and I upgraded to 5.1(1a) without upgrading EPDL image
Stefano
You should upgrade the EPLD image also. As you can see from the following link, the EPLD image is different from the software.
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/epld/epld_rn_5.1.html
jerry
hi,
i have the same issue and just followed what you have said.
when i try to upgrade the epld on a 10gb module i get the msg
EPLD upgrade failed. Exiting..
Failure reason: Chain connectivity is broken while upgrading the FPGA
i have tried updating this on another module (1gb) and thats seems to be fine.
any thoughts on this pls ?
thanks
